Старый 20.01.2013, 18:02
Аватар для Don
Don Don вне форума
Ну и так же еще допработы: Выкладываю на английском - кому интересно - можете перевести (в т.ч. через Гугл - вроде более-менее понятно)
Все работы были заранее согласованы (в том числе по цене).
Короче, машину и вправду должна быть как новая
- Airbag grey leather with special fiber, leather patch with embossed Porsche and airbag symbol with montages
- 4 black floor mats as a set
- Rear window glass with heating wires
- Conversion of mass flywheel clutch on dual-mass flywheel and new clutch plate
- 5 speed gearbox revision performed wheel, completely renovated 4-point bearing, synchronizer rings renewed shift fork replaced, pinion replaced (wear) gear dry iced
- Transmission midsection housing replaced (old parts broken)
- Front axle differential assy. Revision, Pinion renewed oil seals replaced, iced differential dry
- Updated 4 piece shafts, gasket
- Starter renewed only Material
- The master cylinder on the transmission replaced (Hanging clutch pedal)
- The slave cylinder at the Pedals renewed the clutch pedal
- Steel braided hose on the transmission install (substitute porous rubber hose)
- Electric Light machine with fan houseing and expand, houseing painted in Mineral Silver, fan painted in silver gold (we original) Replace alternator:
- Replace distributor in exchange Only Material:
- Brake caliper paint removal, new black powder coat, original Porsche logo and powder clear coat seal:
- 4 x Stainless steel brake lines to install the brake calipers
- Galvanize existing 4 piece drilled rotors, rust removal
- Engine Steels around revolve 6 trays,
- Remove Emptykat, clean and coat Therm
- Removing center silencer, fitted AP Cup cross tube 76 mm in stainless steel
- AP Cup tailpipe in stainless steel
- White Blinker 10 parts kit including fender turn signal
- 2 x new front fog lamps
- Suspension strut front
- New rear suspension strut
- Plan 3 x bonnet and milling are leaking
- Make 1 x valve cover new age components are broken out
Последний раз редактировалось Don; 20.01.2013 в 18:05.
Старый 20.01.2013, 20:27
Shag1 Shag1 вне форума
Олег, а новые детали которые они сняли ( например легкий маховик ) они отдадут?
Старый 20.01.2013, 20:35
Аватар для SergZ
SergZ SergZ вне форума
То что восстановили сцепление в сток это очень правильно
Старый 20.01.2013, 20:56
Аватар для Don
Don Don вне форума
Саш, я думаю, что если нужно, то отдадут все, включая крышу, крылья и бампера. Но тащить весь этот металлолом обратно, с учетом границ, таможни и т.п. (тем более, что еще не решено как машина поедет домой) у меня, честное слово, нет ни малейшего желания. Это же не поводок для AlexRS в чемодане привезти
Старый 20.01.2013, 21:06
Это я как Гобсек, все в дом, жалко нужные штуки выбрасывать )))))))))
Старый 20.01.2013, 21:20
Аватар для Don
Don Don вне форума
А мне итальянцы нравятся, которые в празднование Нового года весь старый хлам с балконов выбрасывают
Старый 20.01.2013, 22:49
Аватар для Maxel
Maxel Maxel вне форума
ты сделаешь многим подарок тут - кому нужны такие редкие детали
попроси их оставить всё целое
я поганю туда техничку по любому!
постараюсь всё забрать
тут раздать
мы своих не бросаем
тем более в Германии
Старый 20.01.2013, 23:04
Аватар для Don
Don Don вне форума
тут раздать
мы своих не бросаем
Я сомневаюсь, что там будет что-нибудь целое
Но если хочешь заморочиться со всем этим - напишу, не вопрос
Старый 20.01.2013, 23:09
Аватар для Maxel
ну тебе виднее что они меняли
что не меняли
если была замена из серии - одно крыло новое и второе целое тоже новое
почему бы и нет?
Старый 20.01.2013, 23:33
Аватар для Don
Don Don вне форума
что не меняли
почему бы и нет?
По кузовному железу там все однозначно прогнивший хлам. У меня на каждую деталь, которая требовала замены по несколько фоток крупным планом. Думаю их (фоток) штук 300, я ж их не все выкладываю. Я , кстати, предлагал, коли уж почти весь кузов новый, заднее правое крыло, дверь и капот с багажником тоже новые поставить. Но немцы отговорили, сказав, что старые в хорошем состоянии.
Старый 20.01.2013, 23:37
Аватар для Maxel
да ты всё правильно делаешь
если надо - менять!
Старый 20.01.2013, 23:54
Аватар для Winston
Winston Winston вне форума
К сожалению в связи со своей молодостью и малоопытностью я лишился вохstera S 320 сил (были и такие в заводской комплектации ), но тем не менее у меня сложилось устойчивое мнение о том, что наши сервисы не обладают полной информацией об автомобилях, которыми торгуют а тем более о всех версиях которые выпускались в ограниченной серии.
Старый 21.01.2013, 00:31
Аватар для New
New New вне форума
к сожалению о такой версии я не слышал...
Старый 21.01.2013, 04:10
Олег, а я не случайно ранее спрашивал про состояние двигателя... С другой стороны, чем бОльшего кол-ва деталей коснётся рука немцев, тем лучше для машины! Скорее ей вернуться домой и в самом лучшем виде! И в очередной раз респект за фундаментальность проекта!
