пока на английском
A legend re-born - new Porsche 911 GT3 unveiled in Geneva
• Purpose-built normally-aspirated 3.8-litre flat six engine develops 475 hp, rev limit 9,000rpm
• Seven-speed PDK double-clutch transmission with unique steering wheel paddle-shift
• Innovative active rear-wheel steering increases cornering agility and enhances high speed stability
• Acceleration from 0-62 mph in 3.5 seconds; top speed 196 mph
• Sub-7 min 30 secs lap time around Nürburgring-Nordschleife
• Available to order 4 March, priced from £100,540 – first UK RHD deliveries November 2013
The engine, transmission, body and chassis are entirely new, extending the breadth of ability offered by the previous 911 GT3 by an impressive margin. Together, they ensure that the proven characteristics of this track-inspired sports car are preserved, while also allowing more sophisticated day-to-day suitability – not to mention a highly emotional ‘fun factor’.
The powertrain of the new 911 GT3 comprises a 3.8-litre flat engine developing 475 hp (350 kW) at 8,250 rpm, a Porsche Doppelkupplung (PDK) double-clutch gearbox, and high-traction rear-wheel drive.
The six-cylinder engine is based on that fitted in the 911 Carrera S, but shares only a few common parts. All other components, particularly the crankshaft and valve train, were specially adapted or developed for the GT3. For example, Porsche is once again using titanium connecting rods attached to forged pistons. These basic modifications set the stage for an extreme high-revolution engine capable of reaching up to 9,000 rpm. The dual-clutch gearbox is another feature specially developed for the GT3, with characteristics inspired by the sequential gearboxes used in motor racing, thus granting the driver further benefits when it comes to performance and dynamics.
The new 911 GT3 is designed for further gains in precision and lateral dynamics throughout. Porsche is using active rear-wheel steering for the first time. Depending on the speed, the system steers in the opposite or the same direction as the front wheels, thereby improving agility and stability. Among the other new driving dynamics features are the electronically-controlled, fully variable rear differential lock, and the dynamic engine mounts.
The height, toe and camber of the newly-developed all-aluminium suspension is still adjustable. The new, 20-inch forged alloy wheels with central locking are used for optimal contact with the road. Traditionally, the 911 GT3 comes as a two-seater based on the lightweight body of the current-generation 911 Carrera. However, the front and rear part are always model-specific. For this latest generation, the 911 GT3 is 44 millimetres wider than a 911 Carrera S across the rear axle. Another clear identifying feature is the large, fixed rear wing. This makes a decisive contribution to the exemplary aerodynamics of the new 911 GT3, which combines low air resistance with a further increase in negative lift (downforce).
As a result, the new 911 GT3 once again sets fresh record performance values. At full acceleration from a standstill, 0-62mph is passed after just 3.5 seconds, and 124 mph in less than 12 seconds. The top speed of 195 mph is reached in seventh (and thus top gear) of the PDK transmission. The lap time on the Nürburgring-Nordschleife is even more impressive: the new 911 GT3 completed this track, commonly regarded as the most difficult in the world, in less than 7:30 minutes. While every Porsche is proven around the Nürburgring, this credential is particularly relevant for the new model as around 80 per cent of 911 GT3 customers also drive their cars on race tracks.
Porsche 911 GT3 Specifications*
Body: Two-seat Coupé; lightweight body in intelligent aluminium-steel construction with wings, doors, boot and bonnet lids made of aluminium; two-stage driver and front passenger airbags; side and head airbags for driver and front passenger.
Aerodynamics:
Drag coefficient cd: 0.33
Frontal area A: 2.036 m2
cd x A: 0,672
Engine: Water-cooled flat-six engine; aluminium engine block and cylinder heads; four overhead camshafts, four valves per cylinder, variable inlet valve timing (VarioCam); hydraulic valve lifter; direct petrol injection; one three-way catalytic converter per cylinder bank, each with two oxygen sensors; electronic ignition with solid-state ignition distribution (six active ignition modules).
Bore: 102.0 mm
Stroke: 77.5 mm
Displacement: 3,799 cm3
Compression ratio: 12.9:1
Engine power: 350 kW (475 PS) at 8,250 rpm
Max. torque: 440 Nm at 6,250 rpm
Power output per litre: 92.1 kW/litre (125 PS/litre)
Maximum revs: 9,000 rpm
Fuel type: Super Plus
Electrical system: 12 Volt; alternator 2,100 W; battery 95 Ah, 520 A.
Power transmission: Engine and transmission bolted into combined drive unit;
seven-speed Doppelkupplung (PDK) with controlled rear axle differential lock and PTV Plus.
Gear ratios PDK transmission
1st gear 3.75
2nd gear 2.38
3rd gear 1.72
4th gear 1.34
5th gear 1.11
6th gear 0.96
7th gear 0.84
Reverse 3.42
Final drive ratio 3.97
Clutch diameter: 202 mm/153 mm
Chassis: Front axle: strut suspension (MacPherson type, Porsche optimised) with wheels independently suspended by transverse links, longitudinal links and struts; cylindrical coil springs with internal dampers; electro-mechanical power steering.
Rear axle: multi-link suspension with wheels independently suspended on five links; cylindrical coil springs with coaxial internal dampers; active rear-wheel steering.
Porsche Active Suspension Management (PASM) with electronically-controlled dampers; two manually selectable maps.
Brakes: Dual-circuit brake system with separate circuits for front and rear axles; Porsche Stability Management (PSM); vacuum brake booster; electric duo-servo parking brake; auto-hold function.
Front axle: six-piston aluminium monobloc brake callipers, perforated and internally ventilated brake discs with 380 mm diameter and 34 mm thickness.
Rear axle: four-piston aluminium monobloc brake callipers, perforated and internally ventilated brake discs with 380 mm diameter and 30 mm thickness.
Wheels and tyres: front 9 J x 20 with 245/35 ZR 20; rear 12 J x 20 with 305/30 ZR 20
Weights: Unladen weight (DIN): 1,430 kg
Permissible gross weight: 1,720 kg
Dimensions:
Length 4,545 mm
Width 1,852 mm
Height 1,269 mm
Wheelbase 2,457 mm
Track widths: front 1,551 mm; rear 1,555 mm
Luggage compartment capacity: front 125 litres; rear 260 litres
Fuel tank capacity: 64 litres
Performance: Top speed 196 mph (315 km/h)
Acceleration: 0-62mph (0 -100 km/h) 3.5 secs
Fuel consumption (NEDC):
Urban 14.9 mpg (18.9 l/100 km)
Extra-urban 31.7 mpg (8.9 l/100 km)
Combined 22.8 mpg (12.4 l/100 km)
CO2 emissions: 289 g/km
Emissions class: Euro 5
